4000GT
Well here is the story. The old powersteering has a cooler and a line to the fluid tank. But I see the 1UZ fluid tank on the pump doesnt have an inlet?
Here is a pic, A used to run through the cooler and go to the fluid tank, B used to go to the pump.
So the question is, can I run B to C and then make an inlet on the fluid tank and run A there and drain through D to the pump?
