HI
My 92sc400 was running great, but, i started to hear the starter motor dragging. The car was running great up to this point. I had the starter motor replaced and a week after getting the car out of the shop. It developed a low rpm rumble and felt like it was running on 6 cylinders. Took it to the lexus shop this time, and they said to put back denso plugs which they did, ouch 300 bucks. ran great then 30 minutes later ran crappy low rpm rumble and running on 6 cylinders,. They did a compression check and found cylinder 7 no compression. leak down test air came out intake side of manifold. took to another shop and they said cylinder 7 also no compression. what is strange is that how does a car run great for a week, then run on 7 cylinders , replace plugs run great again and then no compression, something does not add up. lexus mechanic thinks i might have a bad intake valve in cylinder 7. why would it run good for a week, then lousy, then good. if its a bad valve it should never have run good.
one person told me to suck in some water into the intake because my valve could have carbon on it. tried it no luck. any ideas, spent 1300 bucks on starter and now my engine is blown, something doesnt add up.
you guys are experts, i've read some threads, hope someone can give me some ideas to try. dont think im tech good enough to pull the heads.: ive owned the car since 60,000 miles and its was running great until the starter replacement
