G gsrt085 Member Nov 13, 2005 #1 Hi all, my car is running like crap, i'm getting code 31 one can anybody help me out with what to do? it's a crown 1uz cheers
S sideshow Active Member Nov 13, 2005 #2 code 31 is airflowmeter why all of a sudden there are afew people with airflow meter problems is it a certain importer or just bad luck arent u the one who had ecu problem was it the ecu i guess not if u have a code 31 ecu is usually the last thing but anyway was yr loom complete or where the plugs on the ecu all cut just incase it might be the wiring u should see if u can borrow a crown airflow meter from someone locally
V V8TOY New Member Nov 13, 2005 #3 the plug to the air flow meter might just of come out, that happened to me. Worth checking. does it die when sitting at idle.
