As some will know I've sold off my supercharged engine as I'm just getting too old for it!
I was originally going to replace it with an Chev/Holden LS3 but I figured the car is set up for th UZ so being lazy I've decided this is the way to go.
I can get 1UZ's from about $1250.00 up to $2,500.00 depending if I want to be raped or not. Not!!
I can get a 3UZ-VVTi for $3,000 in a half cut. This is quite local and would be easy to collect, strip out and use.
Is it worth going for the 3UZ?
Keep in mind I'll be using my old headers which are 1 3/4"4 into 1's with 3"exhast with a cross pipe. The engine bay also has excellent cold air intake and it flows enormous amounts of air.
I know the 3UZ has better bottom end power and in a 1900kg vehicle that would be handy but my car needs a rear sump and as best I can ascertain the engine is front sumped. This is minor problem as for a rear sump you need the dipstick to enter the sump directly (like a Soarer) or through a Crown head on the wrong side of the engine, As I did have.
I can see a few problems with a 3UZ if I can't check the oil level (I use a CRS rear sump) but otherwise it looks like a good thing.
Lastly the transmission is a 5 speed Nissan Patrol manual.
What are people's thoughts.
I plan on buying something this week so I can put my car back together.
