I am in the process of putting a 1uz into a ln106 hilux which will all sit onto of a nissan gq patrol chassis and suspension. All of the metal work and paint etc I have covered but the only auto electrics I have done before is wiring up some speakers. The engine is out of a toyota soarer with a 40-40-40 plugs and hilux was originally 2.8L diesel. I have spent plenty of time staring at the wiring diagrams and am thinking that I might buy some bits and have a go at starting the wiring but still not 100% and want to double check to make sure I am on the right track and see what I have missed.
Use the original starter relay that is already in the hilux - wire up the trigger wire coming off the starter - I think it is black with red strip
EFI relay wired up on a 4 pin relay
85 - Pin 24 (MRel)
86 - Earth
30 - +12V (Battery)
87 - Pins 31 and 32 (+B and +B1)
Relay for power to igniters
85 - ignition from key
86 - Earth
30 - +12V (Battery)
87 - BLK-ORG wire to ingniters
Fuel Pump Relay using 5 Pin
30 - Fuel pump.
86 - Oil pressure switch wire.
85 - Ignition.
87 - ignition Start wiring supplying 12volts only when the engine is being cranked.
87a - Ignition
Is that anywhere near close?
Thanks in advance
85 - Pin 24 (MRel)
86 - Earth
30 - +12V (Battery)
86 - Earth
30 - +12V (Battery)
30 - Fuel pump.
85 - Ignition.
87a - Ignition
Thanks in advance
