Hi All, My engine has a starting problem and is gradually getting worse any help would be appreciated
When starting it will wind over for 4-5 second before starting with some help from the Accelerator, It also seems to be down on power and using alot of fuel (seems to run rich). No error codes came up when I did a diagnostics check.
It also has an Idle problem which may or may not be related, it will idle high sometimes while other times it will hunt and eventually stall, I've cleaned out the ICV (spun very freely) and it didn't fix the problem
My thought's are maybe a blocked Cat converter or a vacuum leak (but i can't find one)
Again any help would be very appreciated
