-Nemesis-
Seeing as there's some guru's here, I thought i'd post some pics of random lines here and see if you's know what is what and where they should end up...
I just started tinkering this arvo, getting the timing belt started. Some of these lines i have theories about, but someone may know exact.
Ok first one is down near the crank pulley. Both lines have just been cut when they took the motor out. The top one is a solid metal line, and the lower a rubber hose:
Moving around. This line was in the way of the left cam cover so I took it off. It comes from the thermostat housing, and exits on the drivers side behind the power steer pump:
![frontbottom.jpg](http://www.users.on.net/%7Ebryntrace/1UZFE%20Project/service/frontbottom.jpg)
![thermo.jpg](http://www.users.on.net/%7Ebryntrace/1UZFE%20Project/service/thermo.jpg)
