rwdfreak
Hi there,
The donor is an 1991 LS400 with 190 k miles on the clock. I got the entire car in running order about a month ago.
I'm pulling the engine tomorow an basicaly I'd like to know what to take care of when removing the engine. What should I try not to break and what should be spare. I'm asking this because I know most of the members here that swaped the engine probably got only the engine and tranny with most of the needed accessories. Was there some parts that you'd have liked to have in hand.
The main thing about my project:
-It's going in a 1985 Celica
-No A/C (too much work, temperature is only over 90deg F 2or 3 month a year.
-I'm going to use the factory Celica W58
-I'd like to use the Stock 1UZ ECU, but I know I'd need to do something for the transmission input (might go for a megasquirt or other standalone if I need to).
-For now I'm trying to keep the cost as low as possible until the engine is in the car and is properly working. Then next winter I'll go for a performance rebuild an other goodies.
So asside from the obvious parts like MAF, igniter and EFI loom, what should I look for?
BTW I'm in Canada so it's al USDM spec. Also most of the other parts on the LS are useless to me. If anyone want anything it's in the part-out section.
All comments, informations are welcomed. Thanks
