mdcmotorsports
I need some help with this car.
Im going to post every thing thats been piling up:
1. I need a master (drivers) window switch. Don't care what color. As long as it works and is under $75.
2. I need a drivers side seat belt assembly. Gray color.
3. When I turn on my overdrive, the light on the dash blinks. Its a constant steady blink.
Ive tried pulling codes. No transmission codes were present.
3a. When overdrive is turned off, the transmission shifts very odd. First gear goes to 1800rpm, then shifts to 2nd. 2nd starts at 15--rpm. 3rd is short behind 2nd. Shifts at 1800rpm.
4. I can't get my traction controll to turn off. The button is plugged in.
5. The "birdcage" light for the coolant overflow bottle won't turn off. The coolant overflow is full.
6. The airbag light is on. Ive checked all the fuses. Where else do I need to look?
7. The fuel computer is missing from the trunk via the previous owner. Supposedly it has a walbro 255 in the tank. FP & B+ have been jumped to keep the fuel pump opperational. What do I need to do to return this back to NORMAL stock opperation?
8. The fog lights don't work. The passenger fog turns on when you turn on the right turn signal.
9. The headlights were "upgraded" (insert sarcasm here) by the previous owner. Again, its junk. The HIDs installed aren't very bright. The regular lamps inside the head light fixture (next to the projectors) are very dim when you turn on the low beams. High beams appear to work just fine. How can I get some original lamps and some original headlight electrical plugs?
10. The radio has a high pitch whine that goes parallel to the engine/transmission rpm. Sounds supercharger like....
Thanks guys in advance.
