Armyman2445
Well I'm back and need to know the scoop from all you 1uz guys. On my first rampage: I scored a low mile 1uz from the Soarer, 550cc injectors, and a M112 off a Cobra. I was just planning on buying the adapter kit from Bullet for the supercharger and installing .074 head gaskets with ARP studs, and let her go at 10lbs. But I WANT MORE POWER. SO...... HP wise: a 4.7 swap or the 5.2 stroker kit. (Either will be bought from Lextreme). If I go with the 4.7 or 5.2 I would drive it like she was for a while then mount the supercharger. Those durn adapters are expensive. Then run a 4.7/5.2 with a M112 at 10lbs.
Before anyone goes there. The heads are at the machine now getting a full port, and larger valves. And the intake will at least be gasket matched. I am uncertain on wheather or not to upgrade the cams or not.? I will be attempting to fab up some long tube headers as well. (looking to do a 3/4 stepped to 7/8, but at least 3/4)
This is a pure daily driver. So which is the better option 4.7 swap or 5.2 stroker????
