This inventor from Greece has some outstanding creations. The following link is to his FVVA (Fully Variable Valve Actuation) that allows an infinite range of duration and lift within the confines of the lobe used.
http://www.pattakon.com/fvva/FVVA.htm
Go to the exe on the page and pull up an animation that allows you to try whatever combination you wish.
Once that makes sense you can go and review his Desmodromic Variable Valve Actuation which is his latest evolution of the FVVA and allows the full control WITHOUT the weight and resistance of valve springs. This will allow operation at VERY high RPM and allow an engine to operate with optimal valve timing for any and all RPM/Load conditions. Truly mind boggling when you start getting it into your head!!!
http://www.pattakon.com/fvva/DVA.htm
