Fuel system help in buggy
ethann
Good evening all,
Just setting up the fuel system in my buggy and could just do with some info on what to do.
In tank I have 4 walbro pick ups in each corner, then a 044, all running -8an fittings, now the issue I have is what do I with connecting -8 to the engine?
Correct me if I'm wrong but the m12 banjo fitting on the injector rail also has the fuel reg on it? I can't find an m12 banjo to -8 only -4. Could I do away with the banjo fitting and fuel reg an run an external fuel regulator?
Or is the stock fuel reg not where I'm thinking it is?
The Banjo fitting on the fuel inlet has a pulsation dampener on it. The fuel reg is on the outlet located on the other fuel rail if we are talking non VVti engines. The regulator has a vaccuum hose going to it where the dampener has a screw in the middle of the unit.
VVti engines have two dampeners on the back of each fuel rail. Cheers
Awesome, thanks for that gloverman.
Cleared up abit, makes much more sense.
Will drop into local speed shop and get some fittings :)
