bansheebuzz
When i purchased my crown majesta cut i was unaware that the system required a fuel pump ecu. After some searching without any luck i decided to work a system to run the pump.
I used a common 12v change over relay.
86 - ignition
85 - oil pressure switch or alternator L terminal
30 - to fuel pump
87 - to ignition switch start terminal
87a - to ignition
How does it work? well when you turn ign on the relay will energise and connect fp to start wire so nothing will happen. The you crank the engine and this will power the fuel pump. The engine will fire and oil pressure(or alt) will then release the relay. This will disconnect the start curcuit from the pump and switch ign power to the pump. If the vehicle stalls, the pump will stop due to lost oil pressure/alt not charging.
86 - ignition
30 - to fuel pump
87a - to ignition
