Fuel pump relay location
DVSMOTORSPORT
Hi guys, I'm trying to find the fuel pump relay on my toyota soarer/lexus sc400 with the 1uz-fe
Also if it makes a differnce its RH Drive
Ben
is it the relay or the fuel pump ecu
the fuel pump ecu is on the passenger side trim behind the front doors
so imagine if u sat in th eback seat on the left hand side
well the trim on yr left hand side is where u look
the fuel pump ecus on soarers commonly fail
Cheers mate, I didn't realise there was a fuel pump ecu as well, I'm having problems with the alarm in my car shutting off the fuel pump, at least I'm pretty sure its the alarm anyway.
Basically I can sometimes start the car and it will run fine untill I switch it off, but other times it will start and I can see the fuel damper with the screw on top die down and the engine will stop.
I know the alarm is faulty so I was assuming I hadn't disconnected all the immobilisers yet and was trying to find were else it had been wired to, but does that symptom sound like the fuel pump ecu to you guys?
Ben
i remove 10 alarms to fitting 1
they are the worst invention
problem is over here we have dodgey chineeeeseeee guys who supply and fit alarms
for 200 bucks and they literaly twist wires together
i stay way clear of alarms
worked on one car which had 2 alarms and a tracker biggest heap of shit and waste of money this was
it was a nightmare to work on
Cheers for that mate, Yeh we have some pretty dodgy alarms over here too, the one in my car is a uniden, these things come from the factory faulty.
