fuel pump ECU
alunwill
HI all,
I have an LS400 and my fuel pump ecu has packed up. I'm wondering if a soarer unit will replace the item I have.
Does anyone know if an 89570-24010 is compatible with an 89570-50010 unit.
thanks
al
just an after-thought, are these both pulse width speed control rather than the old resistor system. It's a 93 reg.
thanks
al
They both work the same. The only reason the part numbers are different is the different model codes ie 24 is soarer and 50 is LS400 /celsior. Apart from that the part number is the same. Cheers
