PeteWilliams
Are any of the 1UZ flywheels that are available designed to accommodate the pressure plates from either the 3RZ, 5VZ or 2TR-powered Tacomas which use the larger 250mm (9-7/8") clutch disc? From what I've seen, they're all for use with the pressure plates and 9-1/4" discs of the 3SGTE, 3VZ, 7MGE, etc. The only exception being the K's Racing flywheel from Thailand, which I'm guessing uses a 260mm clutch disc and pressure plate from the KZ and KD-series diesel engines. If there are others available, please enlighten me.
