Japanese_Mouse
Hi
I just bought a 1990 UCF11 Celsior last week, and I decided to change the engine oil. Which was straight forward, as expected. I put in 5L of Penrite semi synthetic oil and I bought a new Toyota Oil fiter (90915-YZZD4) and I also installed a new sump plug gasket (90430-12031).
The car has 98K KMs and looks to be the genuine mileage, everything works inculding the air shocks, cd stacker, heated mirrors and the electric seats.
While I was under the car I noticed a few drops of reddish sticky fluid dripping from around the crank pully, just above the front sump lip.
Im not sure what fluid it is. Its a bit watery but still leaves residue on white paper. My inital thought was power steering fuild. But I put a bit of the power steering fuild from the dip stick, on th esame test white paper and its competely different.
Ive topped up the coolent with distilled water (red awful looking stuff) and topped up the power steering resevoir. Hoping to see a drop in levels tommorow.
This car has the hydraulic powered fan.
I think its the water pump.
If its the water pump, shall I just change that item.?
The timing belt looks good.
Thanks
Thanks
