E extremetoy2000 New Member Jan 26, 2010 #1 Sorry for the noob question but what is the floor switch under the gas pedal on my 1992 SC400? It only activates when the pedal is floored.
Zuffen Super Moderator Staff member Jan 27, 2010 #2 It tells the transmission computer the throttle is WOT and it's time to select a lower gear.
XR8tt Active Member Jan 27, 2010 #3 N20 switch on Sneaky petem ??.. http://www.prostreetonline.com/x/nos-sneaky-pete-kits.asp Yep Kick down switch...
E extremetoy2000 New Member Jan 27, 2010 #4 Ok that makes sense. I guess the next question is what is the linkage going from the throttle down to the transmission for then?
XR8tt Active Member Jan 27, 2010 #5 A modern trans would have this done through ECU, TPS etc electronically .. Linkage is to tell trans it can kick down manually..
