I have begun the long road down the "which flywheel/clutch combination" path.
I am using a custom iron clutch and custom pressure plate. I really want to stick with an aluminum flywheel (dellow and castlemans are out) and, obviously, a steel insert... fidanza style
I have been in conversation with fidanza a few times... is anybody interested in a group buy on fidanza 1uz flywheels? I am currently kicking around two ideas
(1) 3sgte flywheel with 1uz crank shaft bolt holes in the center instead of mr2 style, meaning this would be a direct bolt-on as long as a 3sgte clutch and pressure plate are used
(2) 3sgte flywheel with blank crank shaft bolts, meaning that you would need to have these bolt holes machines yourself.
Interest..?
Interest..?
