My engine (1UZFE sc400 '93 with Richwood M90 kit - 7 psi, over 200K miles) problem starts 4 months ago, I will try to explain as much as I can, hopefully some one can help. First of all what was good, starting engine - ok, idling high 1100 rpm ??, shift to "D" 750 rpm. So, when problem started I notice that at 7psi engine go to red on A/F meter (LED A/F - lean in left 4 cylinders, right 4 - OK) but not too much and only when throttle is open very fast. This is probably related to sucking oil in TB - installed "catch can" to fix - my another thread.
Bigger problem is shaking engine when car is in "D" and not moving, when start moving it is combination of repeated pulling and hesitating and left 4 cylinders in red at A/F or nothing. Looks like problem in left side related to fuel or ignition.
So I changed last week: new OEM ignition wires, new plugs (recommended on this site, /w recommended gap), new distributor caps, new distributor rotors, ultrasonic clean injectors (Supra 315 cc/min), new fuel filter. Start a car , adjust fuel pressure at 40 psi, but still shaking engine, different (bad) sound from left exhaust pipe. The right 4 cylinders look ok at A/F, but left 4 cylinders not even lean - not all cylinders firing ????. Stepping on gas left side of A/F almoust always lean, right side ok.
After all this changes the original problem still exist, it is even worse - more shaking, and car like this is not for driving. Also there is not check engine light on, no codes.
This problem is probably not related to FI.
Just thinking what next to change or check:
-> injectors wires
-> ignition coils
-> fuel pump
-> some sensors ???
I will really appreciate any help.
-> injectors wires
-> ignition coils
-> fuel pump
-> some sensors ???
