Here's my problem guys: I've just changed the tb, cranked it up and it ran nicely at the startup rpms, once it warmed up the idle became irratic - fluctuating and almost dying out.
I pulled fault codes: 100 (MAF), 110 (IAT SENSOR), and "pending" codes 300 (random multiple cyl misfire) code: 1346 (vvti sensor circuit - bank 1, and 1351 (vvti sensor cir. bank 2).
Any ideas what went wrong - it ran just fine before I changed the TB. I did disasemble the right cam, but put everything back the way it was.
Would the timing be off, because I thought the vvti adjusted the timing automatically, or hopefully maybe I didn't plug an electrical or vacuum hose, any help from the resident 1uz vvti experts would be very much appreciated. Thanks much.
Cheers,
LS400GUY
Cheers,
LS400GUY
