lill daddy
hey guys,
so today my 1uz started doing this strange lurching thing, it kind of cuts the entire ignition for a split second then carries on as if it didnt happen... over the course of the day this got worse... i was actually loosing drive from my gear box, like i would manual shift up the gears to D and was like it was in N just free reving?? so limped it home and pulled the cel codes and pulled a 41 (tps) have visually checked the wires and pulled the ecu out and checked for popped caps and have found nothing so far.... does the TPS have a relationship to the gear box and cause it not to shift etc etc im guessing the gear box needs to know the throttle position to know what gear to be in etc... has anyone got a guide to testing the tps i have a multi meter but would need to know values etc and where to get them from... Thanks in advance Adam
