Nasir Jaylen
I am using IS250 2009 model I've found a problem that happens after I started the car and shutdown before getting high temp and is still somewhat high. In this exact example it stops the car for 24hours. It kept a try to fire and stumbled as well as acted like it was swamped. The car’s battery gave up earlier than it would start but eventually got it started after pushing it up to cables (still it took more than a few cranking’s rounds). Some hopeless accelerator’s presses even observed to help; I understand that it should not be needed with inoculation. Once it lastly started it did run forceful and ultimately settled out.
Even, in the past I have faced same kind of problem but it would always run fine and just run irregular sometime.
I am eager to get some suggestion about this…
