As title says..just been down to repco and they say that all is needed is a flow rate of up to 1.8 liters per minute @200 kpa maxing at 550 kpa..
Does this mean that i can get any external fuel pump higher then these ratings and just plug in..? what i wouldn't mind if someone can tell me is.. do I need to run a surge tank..as the fuel system i have just has inlet and outlet with sender i'm guessing (havin't dropped the tank yet) to, My theory is I use a ext fuel pump with a fuel pump flow regulator.. to keep the pressure at the appropriate psi leassoning the chance of air in the fuel also making this a simple setup.(without a surge tank).:feedback: OR do i really have to run a surge tank having then to have a high pressure fuel pump and a low pressure fuel pump etc etc...HELP..:guilty:
Thanks in advance..K
