Has anyone figured out what is the reason for code 12 fault?
Original 1uz-fe ecu. The code says rpm signal fault. Replaced crank sensor and cleaned cam sensor no change.
How i came about this issue is as follows. I tried starting the car and the starter wouldn't turn over. I removed the intake to get to the starter and tested the B postive wire from battery it was fine. I tested the signal wire to the starter relay. It had no continiouity. I then laid my own wire to the relay and the starter turned over but engine wouldn't start as it did not get fuel.
The original wire somehow also gives fuel pump a signal. I then connected the original wire to a relay next to the starter relay and it started but the engines performance is very poor. Does not rev up like it should and backfires when decelerating.
Help would be much appreciated.
Posted for @bennie1023
