stevechumo
I recently used the hydro pump solenoid wire to get the power for my electric fans. I made a mistake by hooking a switched side from the fan relay directly to the solenoid. This switched wire is supposed to be a constant switched 12V. I hooked this wire directly to the cooling ECU. It couldn't power enough the fans so I used the voltage ohm tester to test it. I measured 4.5.V on one side of the solenoid and 10.5 on the other side. After I tested it, the engine won't start anymore. It cranks fine but it keeps dumping fuel without running. I checked all fuses and they're all fine. I haven't checked any relays yet. Could any of you folks help me out on this?
I hope I didn't damage the main ECU nor the cooling ECU. Any info is greatly appreciated.
