Holmsey
Hi I have a 93 LS400 engine fitted to my 1960 F100. I also have a 95? LS400 engine. If I use the inlet, fuel rail etc from the 93 is the basic block the same? Reason is I have the ECU all wired and running on the 93 but tappets rattle and leaks oil from rockers. So thinking if the block heads etc is the same I will just bolt all the 93 stuff on it. Oil tight rattle free engine.
