Hi everyone
I need some help to diagnose some starting problems.
I have transplanted a previously perfectly operative 1uzfe from a 96 LS400 into my 50s Chevy pickup, and I excitedly tried to start it for the first time today.
It starts, but only runs for a few seconds. If I open the throttle during starting it revs up but still dies in seconds.
After it dies it will not start again until I turn the ignition off and back on again. If I don’t do that, and just turn to start from ignition on it won’t fire at all.
The engine was stood for nearly two years before this starting attempt.
I have got an external fuel pump, but still under control of the standard ECU. The pump remains powered for the whole process.
I suspect that the spark is being shutoff by the ecu for some reason, and is only re-established when the ECU is power cycled.
I am using the LS400 instruments, and the revcounter shows the idle at circa 1000 rpm for a second or so, it then rises to about 1300 then the engine dies.
Any ideas?
Thanks in anticipation
Any ideas?
