Hi,
I could really use some help/advice.
I have a 2007 Toyota 4runner Limited 4.7L V8 2UZ-FE
After sitting overnight, when I startup in the a.m. and put it into any gear while holding the brake i get a knocking.
The knocking is definately engine, sounds like lower engine, a lower frequency knock, not like tap or a rattle.
The severity changes depending on the teperature, worse during colder days.
I always let the the motor run for a few min, at least until the needle passes the "c" on the temp gauge before moving.
It lasts for a block or two, or about 2 stop signs, hearing it at each stop sign.
I use Mobil1 5-30, change every 3k no matter what.
I use premium gas (93) from moble or shell
What could this be?
Thanks for any responses,
TONEDOG
What could this be?
TONEDOG
