Guys
I'm just finishing refreshing the two LS400 engines I'm putting into the Cobras and one of them has the usual crack in the bellows section of the EGR tube.
I've done a search on the forum and basically there are two schools of thought, replace the tube as per normal ( I'll probably just weld the crack up as I'm a cheapsgate) or blank the two flanges off on the exhaust and inlet manifold.
It seems that not replacing the tube can upset the ECU and harm gas mileage ( especially when the car isnt warmed up).
What effect does removing the EGR tube have on exhaust emissions once the car is warmed up ( I need to pass an emissions test once the Cobra is completed) and is it ok to assume I can ditch the EGR tube when I go Twin Turbo once the cobra has passed the dreaded SVA ( Single vehicle approval )test.
As both engines are out of cars at the moment nows the time to carry out these fiddly jobs as once in the cars I'll need double jointed elbows just to get near the rear bolts.
Opinions as what I should do please. Replace or remove and why?
Cheers,
Tony
Cheers,
Tony
