Hello all. First time here. I have just bought a 91 LS400 with about 200,000 miles on it and it has failed a smog test. NOx was too high. HC and CO levels aren't even close to max. It has fault codes for TPS out of range and an EGR transducer which makes sense. No EGR = hi NOx. Car runs OK and doesn't do anything goofy. So has anybody changed one of these transducers? How hard is it to change and how much $$ is the part? What do you make of the TPS code and can it have any effect on a smog test?
Kevin
Kevin
