First of all i have a problem with EGR. Chceck engine light dosen`t flash but ECU show EGR error. Vaccum modulator and valve is OK. I dont know the EGR error it`s may be connect with lose power. Engine does not run regularly, sounds like not all the cylinders are working . Engine can`t rise to the max RPM, it`s stop at 4000 RPM and cant rise the top. But in the other moment every think it`s OK. Other example: I ride and the RPM it`s about 2000. I want to accelerate, I push accelerator to the max and I feel the engine loses power. It`s accelerate very slowly and suddenly the power is back, car accelerates normal. When engine runs on LPG the symptoms are less noticeable but there is still problem with power, but not all the time. Sometimes every think is OK. Spark plugs, ignition wire is new.
