Hi guys. I haven't really had to post on lextreme before as my engine has been pretty faultless. ...but I need your help now please.
Started of with tps error code 41
Renewed sensor and spaced correctly but still throws code and goes into what I'm calling limp mode
Will rev fully if done gently but if I dump the throttle it does the limp thing.
So pulled the ecu and some slight capacitor leakage from one or two.
I've ordered new caps but fear board might be damaged
Here is my main question. ....
Current ecu is 89661-50160 with 34,16,22,24 pin plugs
I have another ecu with same plugs. It's number is 89661-50351.
I plugged that in but won't start and engine fault light doesn't flash. So guessing engine and ecu ain't talking.
Can I use this ecu if I swap a couple of wires or is it a no go from the start?
Please help me. .....or has anyone in the uk got an ecu number 89661-50160 that they will sell me
Many thanks for any help
Gary
Gary
