ECU reset for 90 LS400/Celsior
Celsiorous
Hi,
Ive had a search but cannot find instructions on resetting the ecu via the fuse on a LS400. There are heaps of pictures and instructions for soarers but the fuse box seems alot different. Has anyone got a pic they could post of which fuse/fuses to pull in a 1st gen LS400?
Or you can unplug the MAIN EFI relay in your fuse box under the hood.
If you have a Celsior or LS400. The tran and the engine is the same ECU. I would assume by pull the Main Engine Relay will take care of that too.
