ECU Pinouts?
Does anyone have the ECU pinouts of a V8 Soarer?
Like the 2 I attached (they are for the 1JZGTTE so dont use them)
Cheers,
Steve
Look in the tech section of this Site.
There are diagrams of the LS 400 pinouts and I'd be surprised if they're not the same.
I used them to track wires in my Crown and they were quite accurate.
ls 400 pin outs are 4 plugs each plug has 2 rows of pins
not to sure which model the above ones are
i can try find out
they mioght be ls400 but not that i have seen
the above plugs for a 1uz are the least common i have seen
they might be from somethng from alater car
think theyre similar to the vvti 1uz
Ecu Pinouts
Hi Cyberdiamond,
What model soarer do you have, what is the model code on the id plate i have a E- UZZ31 from a 91 soarer v8 it has only 3 plugs on the Cpu, there seems to be a range of diagrams out there they are all different it is close to a sc400 but not exactly the same. I have been digging at the local libuary, picture of plugs is to big to post i will try to pm, i may be able to help
Regards
Lambo
Lambo, I have a 91 UZZ31.
I am finding that the wiring diagrams are all slightly different as well.
My email is stevewilliams<AT>picknowl.com.au
If you could help with the correct ones that would be great :)
Cheers,
Steve
