Before anyone decides this should be in a different section... consider the performance benefits to this simple suggestion... smaller diameter tires
:shock:
That's right, I said smaller. While investigating an upgrade to 18" wheels a number of very interesting things became clear. First of all, it is VERY desireable to lower the weight of tires and wheels. Why? Lower weight allows them to be accelerated easier (power to weight) this gives a REAL increase in the horsepower (or whatever power rating is used) AT the WHEELS, where it counts. Secondly, using a smaller tire DIAMETER has the exact same effect as changing the gearing in the differential.
The case for my 1999 LS400. Stock 16" wheels weigh around 25 pounds
(I will weigh them when I get the chance, if anyone has done so already on the stock 5 spoke wheels please post your findings)
Stock tires are 225/60-16s and also weigh about 25 pounds. Combined weight is 50 pounds per wheel/tire. Stock tire diameter is 26.6 inches. Stock tire tread width (contact patch width) is 7.2".
As I posted in the exterior section (which includes wheels, I suggest a separate tire/wheel specific category) I am leaning towards the SSR forged GT1 in the 18x8 size. This wheel weighs 19 pounds. Going with a 225/40-18 gives me a 23 pound tire with a 25.0" diameter and a 8.3" tread width.
This choice gives multiple benefits.
*Rotational resistance is lessened in 2 distinct ways, 1st the 8 pounds per tire/wheel lighter weight, 2nd is the reduced moment of enertia due to the smaller diameter. Both yield usable horsepower gains at the wheels.
*Grip increases due to the over 1" wider tread.
*Torque at the wheels goes up 6.4% due to the smaller diameter which has the direct impact of having a better final gear. Due to torque multiplication of the gearing, the torque increases the following amount in each gear
![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
assuming a 22% drivetrain loss at peak power)
1st = +144rwtq (2391rwtq vs. 2247rwtq)
2nd = +93rwtq (1551 vs. 1458)
3rd = +61rwtq (1011 vs. 950)
4th = +43rwtq (712 vs. 669)
5th = +32rwtq (534 vs. 502)
Lightening the wheel/tires has a similar impact as using a lightweight flywheel without the engine feel drawbacks.
More positives. Reducing the unsprung weight makes the car handle better and the suspension more effective at recovering.
Also, in this case, the car gets lighter by 32 pounds.
All in all this combination could be good for 2 to 5 tenths 0-60mph and quarter mile.
Drawbacks, harsher and noiser ride due to stiffer sidewalls. More wheelwell gap, in this case about 3/4 of an inch. I have a set of Eibach springs so the gap will be less after those go on.
