Hello I am a new member here and have a problem with my fathers 1990 LS400 that was taken to the dealer and supposedly fixed.
Problem symptoms: Check Engine Light; Rough idling; No Power during acceleration.
Dealer says the check code was a lean condition caused by one of the spark plug wire leads shorting out. Dealer ended up doing a basic tune up, replacing the wires, dist. cap/rotor, plugs. That seemed to fix the problem and the car drove/ran great.
That was 4/5 years ago that the LS400 was taken to the dealershi; but due to my fathers old age, it has only been driven approx. 2000miles since. AND the same symptoms have came up again. The car is rough idling, no power, and smells like unburnt fuel.
I checked the code and it gave me 25 (lean condition); which stumped me as I could smell the unburnt fuel. Checked the plugs and they were all black and fouled. I checked everything else I could (this is my first time ever touching this motor) and I thought I found the problem.
The left(driver side) ign. coil broke at the connector and was barely holding on. This coil was a major pain to remove (I still couldnt get the 14mm bolt back in yet). I exchange it with the right side coil (because it is much easier to get to) and rig it up temporarily to see if that was the culprit. So I put everything back together and start up the car.
Problem is still there (no check codes though). Please give me some suggestions on what to do next. The wires, dist. cap/rotor, plugs are basically new (only 2k miles). Also, Where is the cheapest place for me to purchase an ignition coil. thanks.
