Eagle forged rods
Madaz
Has anyone run the Eagle 1uz H beam conrods? What were your impressions, did the perform ok?
Any negative feedback on them?
Nothing generally wrong with Eagle rods .. I have them in a little Ford Windsor 331 turbo with 483 RWKW..Used similar rods in a Mazda MX6/ 2.5 V6 with turbo, made the motor near bullet proof..
The 1UZ I've built has Argo rods through group purchase way back..
Should easy hold 1000 h.p TUNE and assembly is very important..
Seen these ???
http://www.lextreme.com/Toyota-Lexus-Rods.html
Yes they go ok
Only thing is , you want to increase wall thickness in high hp applications on small end
Options of sbc rod , with a ground undersized big end to 2.00 give more bearing options and bigger small end diameter
They will not make 200 hp per cyl;)
