Dyno results
pwd
East Coast Customs had a dyno day today, and as I was just spectating and there was some spots available, I put mine on to see if if it was going any better.
Couldn't hurt, anyway got some improved results,
so I am very happy with the result, even though it was a stinking hot day.
Dave, can you move this to the forced induction section please,
Its got a whipple twin screw fitted.
Paul, just moved your thread. Great to see it's running better. Did you get your harness problems sorted?
What boost pressure did you see with that run?
Thanks for moving it John.
Haven't sorted the harness yet, but did get the guys to do the run with the TRC turned off, appeared to make a difference, so will looking at that part of the loom.
The other thing was that it was hitting the rev limiter at 5900 revs, the stock limit should be around 6300. Something else to look into.
Boost is 8lbs John.
