Trying to locate this part for my 1992 SC400, I'm calling this part the "center support bearing" for the drive shaft, mine is worn out and making noise and vibrating. The part has a rubber housing and a bearing to support the drive shaft.. I'm getting a clicking noise and a bit of vibration in the drive shaft.. It's time to replace..
Anyways - Looking for this part only and cant get a part # or correct and official name for this? Local auto part stores are asking for the correct name or a part #...
Little help fellas would be much appreciated? Or if you know where I can get a replacement.
Also how can you tell if the drive shaft U-joint needs replacing too after this problem? Will there be noticeable play in the U-joints? I'm wondering if all the play and vibration has wasted my U-joints also?
Also it's been a while and want to give a shout out to all my old Lextreme buds of the past that remembers Jibbby. It's been a while since I've been on this forum and I am saying hello to all my old buds, that is if you guys are reading..
