I have a 4.7 equipped with a drive by wire throttle body, im putting it in a T100 prerunner and i'd rather have my foot phisically connected to the throttle.. i tried searching but didnt come up on anything, has anyone done the conversion?
i did some research and i found that the cable TB has 4 wires going to it from the ECU: VTA, VTA2, VC, and E2 which i believe are used for the throttle position sensor.
the drive by wire TB has those same 4 wires plus E+ and E- which are used to actuate the throttle motor.
the accelerator pedal has 6 leads that go to the ECU: VPA1, EP1, VCP1, VPA2, EP2, VCP2. by the diagram i have it looks like theyre used to send different voltages according to the postition of the pedal through the various wires to get a acceleration value.
if i were to change the TB i should still be able to use the existing TPS wiring to hook up to it but my concern is if i have no throttle input from the pedal going to the ECU will it still run correctly? are there any systems tied into it like VVTi or would the ECU not deliver enough fuel or the correct timing on acceleration?
