ok..its time to wire up the engine..(1995 1uz-fe into old range rover)
i have studied the wiring dia of this model (1995 ls400) its the same as the 1996 dias shown on this site.i have dia for 1991 which wires to use..ie crude version using ign,sta,B+,+b1,nsw,w etc...
now 1995 is differentish, so i need to confirm a couple of things...(oh i am going twin speed fuel pump as its real easy to do.)ecu is 34,16,22,28pin)
a)i still do not need to connect up secondary o2 sensors..?(will the ecu throw out fault codes, if it does whats the voltage it will be looking for from them at correct air/fuel mixture?so i can make up a dongle to fool ecu)
b)nsw goes to +12 on start.
c)its safe to lift the +12v to injectors (as will be dual fuel ie lpg) or will this cause the ecu to throw out fault codes?
d)the power pin (pwr)on the 28 pin plug which has 12v applied when power/normal switch operated is to control the auto box only??or does it change the engine map as well???
e)vapour pressure switch..what does this do..mine appears to still be attached to the now crushed donar car...do i need it?
thanks
thanks
