im trying to swap in a 2uz into a t100 truck, i have everything ready to go except for one thing, my oil pan.
i can tilt the t100 engine mounts on the frame up and the 2uz will bolt to it with the tundra front sump and itll sit perfectly between the frame rails and crossmember, but because im also moving the cab back for tire clearance i need to set the engine back about 2-3"
if i do that then the oil pan wont clear and i dont have the money to get all the stuff to convert it to a rear sump so i was thinking about fabbing a custom oil pan with the same capacity as the stock one and also extending the sump pickup tube. am i crazy or is there a chance this might work?
