I am in the progess of writing an article on Differential Diagnoses for Ignition Failure. I would like to have your imputs and experience of the following failures:
* Coil Failure
* Rotor Failure
* Distrubutor Cap Failure
* Wire Failure
* Spark Plug Failure.
Can you give us detail discription of the signs and symptoms of the above failures or malfunction. Also what are the diagnostic tests can be done to determine the failure.
Your contribution will greatly appreciate and your experience and feedback will help others. This article will be posted in our site under www.lextreme.com/tech.html under general repair section.
Thanks
david
* Coil Failure
* Rotor Failure
* Wire Failure
Thanks
david
