Im sure if we weld the head to the block with head studs on top of that for good measure? no doubt engineering the tight clearances fo the CR will be a fun one. I wonder if the space would be there?
Incorrect, the 4.5L (1FZ-FE)is an Inline-6 configuration. Iron block, aluminum head and it never came with a turbo. The 2010 tundra/Landcruiser's new Diesel is a 4.5L and is a V config, with twin turbos too, was that what you were talking about? I suppose if a 4.7 2uzfe was used instead it would mimic the 1fz-fe pretty close. We would need a lot of engineering to fit 30:1+ CR inside, and I am guessing to say the valves will limit the amount of space we can eliminate with the piston dome? I'v tore apart a diesel or 2 and can say that there isn't much room for anything at TDC, although the short valve lift/height on the early UZ only helps. Also the Iron will deal with the higher heat much betetr than the aluminum block. A frankenstein swap with 1uz heads, 2uz block could be a viable solution if any bored engineers have the balls to try it
Subaru's new new boxer diesel is an alloy block..
I cannot see too much of an issue the manufaterer making diesel's in these style of blocks ??..
Yes some re-engineering needs to be done.. But in the past diesel's where regarded as heavy duty motors..
could use a diesel block. I think it could handle it, as for the engineering required, don't bother a 4.5L twin turbo toyota Diesel can be had, check out VDJ200 series, for the twin turbo and single turbo is on VDJ70series.
Interesting we all speak of 22:1 compression ratio but if you'r running 9:1 (like me) and then run 22psi boost (like me) the actual compression ratio is over 22:1 when on boost.
On that basis the block/rotating assembly can sustain the compression.
I was thinking that exact same thing, then its a simple matter of the right heads/cams/valves/fuel inlet and tuning, which would be acheivable, but cost prohibitive. VD series for the win.
Toyota has diesel V8s, been around for close to 10 years now.
4500 cc turbo charged, comes with 1 or 2 turbos.
Great stuff. roughly 260 hp roughly 750 Nm.
As far as I know they can be found in large Landcruiseres, Lexus 570 and some pickup models.
These mills may be found almost all over the world.
But not in the 2nd largest Toyota producing country, Thailand. Pisses me off, 'cause
I want a 1VD and I stay in Thailand.
