Hi, been a member for a while and need some help now. I recently changed out my starter. Thanks for the tutorial on how to do that...what a job...got everything put back together and now have a problem with number 1 cyllinder not firing. Pulled plug and there is oil on the sparkplug (clean shiny oil), so the plug is not firing. Get fire from the coil and pulling the sparkplug wire to cyllinder 1 does not change the engine rpm. The car smokes a white smoke from the exhaust and will not idle without giving it gas from the pedal and there is lifter noise from cylinder 1. Could I have a stuck lifter or maybe the valve oil seal bad in that cylinder? What could I do to get the cylinder to fire and clean out the oil? Compression seems good in cylinder. Any help will be appreciated. Next step is to take it to shop. Any good ones in Kansas...Topeka area? Thanks all for your help in advance.
