ALI1UZLUX
I have a Celsior motor fitted in a 2wd Hilux running Microtech LT10S ecu. I fitted a crown auto thinking that I would be able to wire up the seperate ECT that come with these boxes to run it; I was told that I could do this as long as I fully manualised the gear box, ie change 1st, 2nd, 3rd manually.
Then I came across this, one of Kdogs older posts
Please someone crush my doubt and tell me I can still use this set up.
The ECT isn't needed if you aren't using the auto.
If you are using an aftermarket ECU to control the engine you can't use the ECT to control the gearbox. The ECT gets the signals it needs from the ECU not directly from the sensors so it isn't possible to use it. If you still wanted full automatic function then yout could use an ECT from an older car such as a cressida which has an ECT which will take signals directly from the sensors.
The speed signals for the ECT (SP, SP1, SS1, SS2 and SSC) aren't accurate in my diagrams. I will update them when I get a chance. The best way to wire these up to is to replace the speed sensor (20pulses/revolution) with the type that puts out 4 pulses/revolution and wire it to the SP1 input on my diagrams. Please correct me if I am wrong someone as I am going from the top of my head.
