Danger Mouse
I have an intermittent problem, where the engine cuts out randomly, but will restart immediately and then drive fine. When it cuts out, the rev counter also drops to zero.
I've had the ute at an auto sparky, who went through the wiring loom and sorted out some dodgy stuff (the guys who did the conversion for the previous owner were very good mechanically, not so much electrically).
Due to the behaviour (definitely electrical), I'd like to check the crank sensor, but before I go crawling around under the ute, can someone give me a quick pointer to it's location?
Any other suggestions? Could also be the immobiliser, the alarm was also installed by the previous owner and it has it's own issues now and then.
