striker
That Bolt is Tight as a...... well you get the point!
here's a quote I found on the forum, it's from peewee
Ok and how would you do that with and engine that is on the stand?
I presume the thread on the bolt is a normal one, ie turning to the right ---> results in the bolt tightning up, and turning to the left <--- results in loosning up.
with a special lever made to secure the front pully (ie not turning the crank) and a heft leaverage from a 1.5 meter piece of alloy tube over the socket.... it still won't come loose.
hints or tips most welcome!
grtz Thomas
I don't have an air wrench nor do I want to use one on a crankshaft pully bolt cause if it breaks.....
Peewee: To get the crank bolt off, use a breaker bar (18" locked rachet) and brace it against the subframe or floor, then crank the motor.
Unplug the ignitors so the motor doesn't start.
Its by far the easiest way of doing it.
grtz Thomas
