I'm having a wee bit of trouble remembering where all the plumbing goes on my engine......again !
There is a vacuum line which runs from the front of the plenum down to the power steering pump, then back up to a tee in the ISCV to inlet pipe. What order do these pipes connect at the power steering pump ? Does it matter what way round they go ?
On the rear water manifold, on the left hand side there is a vertical water pipe connection. Where does this go? From my photos I have it looks like it might go to the EGR on the side of the plenum? If thats the case, where should I connect this line if the EGR is deleted ?
On the front water manifold, on the top right is a pale blue sensor. What is this sensor for ? It has two vacuum lines connected to it. One goes to the top of the throttle body, what about the other one ?
Lastly... the radiator overflow tank. Has 3 connections on it...one looks like it connects to the pipe on the side of the thermostat housing.....what about the other 2 connections.
I think thats all ?
I should have taken more notes ehh ?
Elliot
I think thats all ?
Elliot
